Search Forums | Classifieds (33) | Skins | Language
Jd4455 save hydraulic problem
   Forums List -> FAQ & SupportMessage format
GaryLundberg
Posted 12/30/2021 09:08 (#9406983)
Subject: Jd4455 save hydraulic problem
My jd4455 remote hydraulic service ports When I plug in to the right side I get 2200 pis when i operate the control lever just like it supposed to be. Plug in the left side I get 2200 psi all the time without moving the control lever. I’ve had jd rebuild the complete valve. Worked about 3 months and started same problem again. Already sent 1000$ on it They say probably got a crack in the housing Another 1200$ For a rebuilt one This tractor has 3 remote valves. Funny thing the one next to it just started the same thing. The two on the bottom. The one on top is working fine. Any ideas before I spend 2000 3000$ on replacements
