Search Forums | Classifieds (149) | Skins | Language
Terra gator 1803 project finished with pictures
nbfarms
Posted 12/5/2021 20:45 (#9360631)
Subject: Terra gator 1803 project finished with pictures
Bought this 1803 to use for fall/spring burn downs, spraying wheat stubble, and streaming nitrogen on corn and wheat acres. Have a John Deere 4730 that I’m hoping to save hours on. Also, the 1800 gallon tank is a lot nicer when streaming on nitrogen. I wanted to re plumb the boom with electric boom valves, 20” spacing, and try and keep the added weight of brackets to a minimum. Not sure it was the best solution, but decided to make a new wet boom that cam locks onto the existing boom brackets. Went with high flow nozzle bodies as well. So far I have used it for 10 gpa burn downs and up to 45 gpa streaming nitrogen. Can run 16-20 mph no problem.Only problem I have is I can not get the induction cone to work….instead of sucking stuff down, it blows liquid out through the cone. I believe I have everything plumbed correctly according to the book. Any help on this would be appreciated!!
Edited by nbfarms 12/5/2021 20:51
(DBED1740-5441-4E6E-AC7D-FC970D3A7B2B (full).jpeg)
(A7E04EEB-516B-4B04-B444-B382B11F19B5 (full).jpeg)
(4AEA2271-C2BF-422C-99B3-08D97590B993 (full).jpeg)
(276446B4-4D62-4BDF-8B44-BB50D106FF9E (full).jpeg)
(37BF2F64-8B06-4E1B-BAC0-F8939007FF0C (full).jpeg)
(AF853C4B-14D9-4CD8-A760-6D9951FE170F (full).jpeg)
(C710F0C3-C5B0-4B83-AFE3-868A515B88FD (full).jpeg)
Attachments DBED1740-5441-4E6E-AC7D-FC970D3A7B2B (full).jpeg (95KB - 193 downloads)
Attachments A7E04EEB-516B-4B04-B444-B382B11F19B5 (full).jpeg (176KB - 207 downloads)
Attachments 4AEA2271-C2BF-422C-99B3-08D97590B993 (full).jpeg (138KB - 189 downloads)
Attachments 276446B4-4D62-4BDF-8B44-BB50D106FF9E (full).jpeg (225KB - 208 downloads)
Attachments 37BF2F64-8B06-4E1B-BAC0-F8939007FF0C (full).jpeg (185KB - 176 downloads)
Attachments AF853C4B-14D9-4CD8-A760-6D9951FE170F (full).jpeg (178KB - 201 downloads)
Attachments C710F0C3-C5B0-4B83-AFE3-868A515B88FD (full).jpeg (166KB - 173 downloads)
