Search Forums | Classifieds (21) | Skins | Language
NAT Search Help
   Forums List -> FAQ & SupportMessage format
Posted 9/3/2021 17:24 (#9200992 - in reply to #9200387)
Subject: RE: NAT Search Help
The search here is having issues so has been limited to just one year. It is also a huge data base of previous posts for it to search.
A good way to search is go to google.
In the search bar type site:newagtalk.com,then something about the subject you are searching for then + Expensive Hobby your user name. This should narrow it down for you. It's often helpful to try and make your posts here with something unique in the subject or add keywords to them. That makes it simpler to find them later.
As an example this would be for something of mine.
site:newagtalk.com battery disconnect + Von WC Ohio
