Search Forums | Classifieds (75) | Skins | Language
Raven accuflow flow meter trouble
kirk_vollmer
Posted 5/11/2009 23:32 (#710595)
Subject: Raven accuflow flow meter trouble
NCND
I've got a Raven accuflow NH3 setup that has the two valve system. My trouble is with the flowmeter, when I am going down the field sometimes it gets erratic and show anywhere from 0 lbs all the way to 300 lbs. Then the next time it shows 0 all the time. It doesn't matter if the tanks are full, half full or what it just goes on the fritz. I have replaced the sensor that screws in the top of the flow meter. That helped for a while but now it does the same thing. So I put the old sensor in and that worked for about 30 acres and then crapped on me. Every time I take the sensor out of the flow meter there is condensation and the end of the sensor is wet. Should I be putting some silicone in before screwing it in? I tighten the sensor until it touches and then a little more till the marks on it line up with the flow meter like it is suppose to. I have had trouble with this since it was new and its getting really frusterating any comments will be greatly appreciated.
