Posted 7/4/2009 13:48 (#765454 - in reply to #765441) Subject: RE: Injecting soap into a pressure washer system.
Kansas
I thought about that, but the problem with that idea I'm afraid of pushing the soap through the pump because it might cause foaming and then less lubrication and cause problems.
I could be way off on that one too but I toyed with that idea and then decided there is probably a destructive reason not to do it.
