Bonanza, Or | I believe I like the idea of working in 10' sections and trying to get water to come out the sprinkler outlets. The TL's have a rubber boot like a Valley that is held on by a clamp on each end and yes they are hard to move. DO NOT cut them as you will have to lift up the span to get a new boot on. If you have to slide the boot get some of the lube that is used to put together gasketed pvc and lube up the span pipe so it will slide. | |
