Search Forums | Classifieds (90) | Skins | Language
Battery disconnect kit for JD 84000 tractor
Badger
Posted 12/12/2017 13:25 (#6424014 - in reply to #6423823)
Subject: RE: Battery disconnect kit for JD 84000 tractor
Huntley Montana
I took a 3/8 x 1" flat strap about 6" from  the Ground point by the back of engine drilled 2 3/8 holes on it, bent it to where it was in a good spot, then used a good shut off that I used 1 lug to go through strap & moved ALL of the tractor grounds to other LUG of shutoff, then bolted other end of strap to where the grounds were at before....  Clearer than mud I hope....
