Pierce county WI | Sorry I didn't get back to you. I see the thread got moved. Make sure you clean out the inside of the pipe before you put it on. Any slag or excess wire is going to end up in your engine. Another option is maybe getting an exhaust shop to bend a pipe up for you to. You can use a female coupler to weld instead of a butt weld, or with an elbow it has a coupler end. Also if you can't keep the hose joints together, just weld a bolt to both pipes and then attach a piece of flat steel to the bolts so it can't pull apart. | |
