Posted 9/8/2016 07:37 (#5516572 - in reply to #5516095) Subject: RE: JD 40 series 12V battery conversion and disconnect follow up (pics)
Northeast Indiana (Auburn)
I put two group 31 batteries on my 4440. I ran the + cable under the cab from the battery to the starter and put the cable in the original cable protector wrap. When I did the conversion I used the 4440 every month in the winter so I went with two batteries. It sure starts better now. Where did you get your disconnect switch?
