You're absolutely right Brian,, course John didn't bother to respond. Fire off some wise@$$ illiterate comment then run. Hope you do feel a bit better about it, as does get awful irritating having somebody with less than zero knowledge tell you,," you're doing it all wrong!",, even thou they've no better answer and what you are doing works for you in your situation. Had a little rant of my own,,, http://talk.newagtalk.com/forums/thread-view.asp?tid=71789&mid=509943#M509943 It appears some of the same people didn't bother to read that one either. |
