Posted 4/16/2008 22:09 (#359503 - in reply to #359468) Subject: RE: 1250 24 row planter
Our 55 has two low pressure return ports, one is right below the valve stack and the other is Y'd off the transmission fill port. I don't know if the one on the fill port is factory or not, it looks like it's just an iron pipe fitting welded to the tube with a coupler on the end.
