| ^^This. Had it happen to our own 4450. Engine still ran, but tractor stopped suddenly while backing the bean planter in the barn. Suddenly developed an oil leak on LH side by the clutch valve. Bolt that threads into flywheel that holds clutch assembly together backed out and wore hole in the oil pipes inside clutch housing. The fix is to upgrade all components, including flywheel, to accept 1/2” bolts instead of keeping the 3/8 bolts that was used on early s/n tractors. Ours was close to a $20k fix.
Edited by deeretech1989 9/14/2024 12:00
