Posted 8/6/2024 16:56 (#10841602 - in reply to #10841212) Subject: RE: Yield monitor for 7720
south west in
If going ag leader and going used be sure to get the elevator mount moisture sensor. The early ones had moisture sensors mounted in the auger inside the grain tank. They worked but would gum up and that would give inaccurate moisture readings causing inaccurate bushel readings.
