Search Forums | Classifieds (1) | Skins | Language
brush cutter for mini excavator
krfarms
Posted 1/22/2024 19:11 (#10588319 - in reply to #10588006)
Subject: RE: brush cutter for mini excavator
Greenville, Ohio
I got a Rut 36” brush eliminator with the mulching teeth on the bottom.I really like it. The only issue I’ve had is that I don’t have a case drain so I have to run it on jackhammer mode, and that’s caused a few things to rattle loose. Some lock tight and an all metal lock nuts fixed that. Other than that it’s been awesome. I’m going to add a case drain to my machine so I can run it on normal flow.
(IMG_5027 (full).jpeg)
(IMG_5026 (full).jpeg)
Attachments IMG_5027 (full).jpeg (220KB - 103 downloads)
Attachments IMG_5026 (full).jpeg (243KB - 91 downloads)
