Raven Envizio Raven SCS460 Help!
ILSODGRWR
Posted 9/22/2022 15:20 (#9856228 - in reply to #9856185)
Subject: RE: Raven Envizio Raven SCS460 Help!
Kendall County, IL
delta1860 - 9/22/2022 14:39
1) double check that data logger is turned on in the data menu of the 460
2) I believe that you have to be in rate 1 on the 460 for it to talk to the Envisio
3) for your steering was the steering shield icon in the upper left of the display green or red. If it was red touch it and it should tell you what is wrong
Thank you for the reply. Auto steer is working again but still no mapping or rate display and data logger is on.
